crew chief
- Oct 1, 2008
- 379
- 435
- 63
- Location
- Adelaide
- WK LS1 Turbo, WB Ute, VF 2300 Harrop
Yeah, quick run to supercheap and they will do it. Not sure of cost.
This involves driving it ... is that wise?Yeah, quick run to supercheap and they will do it. Not sure of cost.
In answer to "is it safe to drive" you mean?With all due respect of course.
But do I look more a mug for not doing that, or for leaving the oil filler cap off?Have you not lifted that bonnet for two months?
A very good idea is to check all fluids under bonnets of vehicles weekly
I had worse, The only time I went to a Holden Stealers for warranty was our V2 2002 Monaro complaining a spongy clutch pedal so they bleed the clutch and forgot to put the brake fluid cover back on then when I got home (clutch was getting spongy again) I can smell oil burning so I lifted the bonnet and brake fluid was everywhere, Ripped off all the yellow paint under the bonnet and had to get them to remove the engine to fix it.I had a workshop leave an oil cap off one of my cars after a service and I certainly knew about.
I had a 1 1/2 hour freeway drive home and when I was almost at my door I could hear her rattling, I opened the bonnet and there was oil everywhere.
The same happened on a trip away except it was an oil pressure gauge sensor that failed, again I had oil everywhere.
Both cars were 1970's models.
The engines were never stripped down but in both cases I never noticed any difference when driving them, I'm now very particular about checking my own and other peoples work.
This is the most likely cause for that check engine light @Forg. But don't risk driving it around till you get the scan done. Take an uber or get someone to give you a lift to the auto parts store. OR just order an OBD scan tool online - it should be at your doorstep within a day or two.Oil filler cap off is going to create a vacuum leak, unmetered air entering the intake (via the PCV) that the MAF does not see which will make it run leaner and the O2 sensors will have to compensate for. If it's enough to throw a engine code is the question?
