That's all well and true but it still does not change the fact that you said the SP manifold only works over 6000rpm when I have posted dyno graphs what refutes that point.
If you don't like the facts that is fine but stop making blanket statements which are categorically not true as is clearly demonstrated by the dyno graphs I posted above which were posted online by TK383 and testing done by TP and Micron engineering who are arguably some of the best guys around with Holden V8 motors.
The graphs you posted did not prove this and they're barely readable then you provide a peak figure from a Torque Power single plane all at the same time Tony him self states that for an engine with a mild cam the dual plane would be the better choice.
I've debunked your information and yet you have not debunked any info from Richard Holdner. Richards tests and information is clear and consise.
I guarantee you that Micron, TK and Craig from TP would all agree with Richard Holdner. Yet here we are someone is trying to state that longer runners don't improve low end toeque over short runners. If this was the case don't you think every Kia, Mazda, Citron, VW ect would have the shortest possible runner???? Why do so many OE engineers waste so much time and effort to make variable intakes that lengthen runners at low engine speed then shorten them at high engine speeds??????
Obviously I could give you many soruces of info but you'll keep brining up your info that I debunked and not listen..
