yeah the torker will be a good manifold, to be honest i am looking for one to replace my performer, but the ones to suit VK black are big $$$
the 600 will be a good carb and you will be happy with it, but the problem is it over carburates something cronic down low. because the quaddy uses vacuum for both primary and secondary metering the carburation goes up as the engine needs it, and you can do a couple of 'tweaks' to it to get a bit more fuel or air if you find you need it.
the primary metering on a DP is basically "put your foot down, primary pump will shoot a measured amount of fuel straight down the throat of the carb, power valve opens allowing even MORE fuel through, then metering takes over" which after mucking around with mine for AGGGGES i had to decide if i wanted to launch well or get good top end. fuel economy suffered both ways. lol.
the quaddy was just; tighten that spring, change this spring, change these rods, drill out this hole, set the idle, and BAM! it was awesome off the line and keeps pulling all the way through the rev range.
someone mentioned the 600 vac holley too, and after reading a really good post from delcowizid...
CFM = (CID x RPM x CF) / (2 x 1728)
CFM = cubic feet per minute
CID = displacmente
RPM = well if you don't know this one you may as well go to a different site
CF = correction factor. this is based on the VE% (volumetric efficiency) of the engine. i have a nice chart here for that in relation to cam duration but for stock heads and cams in the 240-250 duration @ .050 use .9
these numbers are all based on the standard 1.5" pressure drop across the carby. this is the part where it gets interesting because it doesn't take a lot of effort to get a decent intake to have less then 1.5" drop which changes the CFM rating of the carb.
there is however a formula for that too.
CFM / square root of( old pressure drop/ new pressure drop)
or 800cfm / sqaure root of 1.5/.5
= 800/1.732
= 462 CFM so a 800cfm carb (measured at 1.5" drop) only flows 462CFM @ .5" drop
(told ya i'd save it)
it would seem like that would also be an awesome carb for a mild 308, but the thing is, the quaddy can be setup to go above 800 cfm if modded right. so once again, out of the two i would still go quaddy.
but yeah. all that is useless info cos you have a holley
ok, well. setup your power valve, get your primary shot set right (there is a changeable cam on the pump arm) set your jets right and really take the time to tune it properley and itll run well. if a little thirsty.
i made this thread a while ago:
https://forums.justcommodores.com.a...odify-quadrajets-also-vac-hose-diagram.121828 if you do land one and wanna play with it. they are pretty easy as long as you know what each bit does.
