Alright you bunch! I agree with the brakes. Poor. I really thought maybe it was just my car, turns out...
Anyways, i have sent some requests to Camshaft suppliers and had varied responses as below.
(This isnt a case of someone being an 'askhole', you have all resigned me to the fact i need to swap the cam, dont rebuild, dont build the engine to match the cam. But im going to do extra due diligence because 3 isnt a lucky number, i want to not have to revisit this again)
I shot an email to Crane, Crow, Camtech explaining basically what i have to you bunch and this is what i received (In Summation).
(sent email attached)
Crane - Helpful, responsive.
- Not an ideal situation…..
- A question I can’t really answer, as your compression ratio is a guesstimate
- Technically you will need to step up to a 286 #884301
- Hard to say if the 284 has enough overlap to cure your problem !!!!
- Could/should/might be ok…. Hate for you to install one and its still detonating
- As for converter stall….everyone has a different thought
- BUT you will sacrifice low end torque and need a small (approx. 2200) stall converter (Please email Dominator for their input)
- Unfortunately not really suited to your main usage
- You might want to try a good high output ignition system
- I would suggest a Crane/Fast HI-6 Box & LX92 coil
- The increased spark output and low RPM multispark could be enough to fix your problem
Crow - Helpful, short responses (leaving me unsure if the request was given the thought required)
- At first a cam was suggested and an order sheet was supplied with no word from the technician View attachment 209793
- I replied asking if this would fix the issue i provided.
- A day later i received an email saying "Yes i think this will solve your problem" from the head of "The Head Technical Department"
Camtech
.No response.
