Whats your oil?
Gmvf350
Central coast nsw
Vf ssv redline
Anyone using Fuchs Supersyn Dexos 1? Have run Mobil 1 for about 10k & due for for 15k service. Just after thoughts on which oil.
revster
30th Anniversary HSV Senator (Gone) MY19 Golf R
You will get many opinions. I have run Mobil 1 the last 5k after running mineral for first 3k, followed by semi-syn dealer Castrol for 5k. I believe in sticking with the same oil in the long run so it will be Mobil 1 changed each 4-5 k forever. Many will say I am burning money but that is just me. :)
revster
If your car is under warranty I would be using a Dexos 1 certified oil. Pretty sure mobil 1 isnt.
It is. Not only have I seen the list of approved Dexos 1 oils but it's what HSV use.
Smashfist
44
SE QLD
440rwhp Cammed VF Ute
Yeh just checked. You are correct. Although I think they have linked mobil 1 to some camshaft issues..
Not the oils fault. You get the occasional pressure relief valve pack it that results in oil pressure being a bit low (but not catastrophic) and it wears the hardening off the cam/lifters.
I've seen it on cars that get only Mobil1, I've seen it on cars that only get Valvoline and I've seen it on cars that get a random mix of oils.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
The issues with the camshafts were soft lobes, due to a manufacturing defect.
Graham downunder
sydney
vf calais
The grade of oil is the important thing GM recommend GF-5 5w-30 ,I used Penrite enviro+ full synthetic for what its worth ,pick some up when its on special at Supercheap . If you change your own oil like i do with most of my car and motorbikes. I drain the oil then put in about 1/2 to 1 cup of fresh new oil to remove the remains of the old oil ,let that drain, then put the sump plug back in . You need about 8 litres including filter .
