Where is this annoying water coming from.
Mike08
No Back seat drivers
Queensland
VE SS Ute
Hi all, this pic shows water in my SS cab. It's in the exact same position on the passenger side as well.
Nothing else other than where it shows up appears to be wet.
Lucky i have good thick rubber floor mates to catch this crap.
Only seems to happen after heavy rain, not after washing or light rain.
Car is a 2010 SS ute.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Had a windscreen replaced?
RiCeY
Australia
Sit in the car and get a mate to pour water over everything and see if you can trace the source.
TraidMarc
Donating Member
South Hedland
www.traidmarc.com
VE Series II SS-V Redline Sportswagon A6 Phantom
This is why I don't take my car out in the rain. Could be coming from the window gully through engine bay back into dash.
Mike08
Queensland
VE SS Ute
Cheers for the reply's guys, will investigate it further and try and work out what is causing it.
Kiddo
You're serious bro?!
Mitsubishi Colt
Yup,
Get a mate to run a hose over it until you spot the leak.
Then get all CSI on it and trace it to the hole.
swingn_wasabi
VE S2 SS-V Redline Ute
Only time I've ever seen water appear in that area was an old Ford Panel van... Had rusted out & anything that ran off the windscreen found it's way through the rusty holes.
If it was happen on the other side, I'd suggest it was the air-con compressor. I know that was a problem in the early model Porsche Boxers (Among other things :p).
I think Kiddo is on the right track :) But it's strange that it doesn't happen after you wash it... Generally that's where the problem rears it's ugly head. Especially if you're using high pressure hoses etc.
