Lionelgee
- May 9, 2022
- 25
- 8
- 3
- Age
- 61
- Location
- Bundaberg
- VY Commordore Executive Wagon
Hello All,
Can someone please let me know which fuse needs to be changed when the automatic transmission's gear position light, the SRS and the fob activated headlights on no longer work. Fob activated headlights on is when it is dark and and while you are unlocking the car with the key fob - if the correct mode has been programmed your headlights turn on as well.
I could not find a fuse that mentions gearshift selector light/SRS or key fob headlight illumination. I know that this happened once before and a new fuse solved the issue. I did check all the 7.5 to 20 amp fuses under the dash - however I could not find any obviously blown fuses. Then again my eyes are buggered too. A hint of where to narrow down the search would be much appreciated.
Kind regards
Lionel
Kind regards
Lionel
