Windscreen Washer Jets Not Responding
Renski
51
Brunswick
VE Calais 2009 Series 1
Hi there,
My VE Calais Series 1's windscreen washers are inoperative, no sound at all to be heard when trying to activate.
Is there something I can try before I bother my auto electrician with that?
Whiteshark68
Queensland
VY Berlina Series II
if you have someone who can assist you and you can access the washer bottle get the other person to operate the washers while you tap the washer motor i can't help you on the position of the washer bottle/motor but usually a few taps will free them up
they freeze up from lack of use and if that is the case the motors aren't hard to replace usually not expensive either
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Washer bottle is bolted to the back side of the reinforcement bar with the pump on the drivers side, if you remove the grille you can get to it from there
krusing
Melbourne, Bayside
If it is the pump,
And you tight for cash, get one from a wreckers, they are cheap to buy.
Renski
51
Brunswick
Okay thanks guys, will have a fiddle with the motor to try to wake him up.
Do I need to remove the water reservoir to access it?
vywgn
No you won't, if you want to remove it there is 3 10mm bolts holding it in place, 2 on drivers side 1 on passenger side, search eBay to give you an idea
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Checked fuse/relay?
Engine compartment fuse box, F21, R15.
