Wiring through firewall
ringfeder3
56
Nsw
Ssz crewman, wm caprice, 2018 prado, hq Belmont u
Where is the best spot to route some wiring through a VT II firewall. I have to run a driving light circuit.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
There is a rubber grommet thing on the firewall to the right of the brake booster, it's sort of diamond shape with round edges and pretty big. I pierced a hole in the centre and feed some wires through it.
Bgrade
44
Caringbah
99 VT Executive S2
On the passenger side behind the glove box there is a hole with a little rubber grommet in it, i used this hole to run the power cable to my new stereo and so it didnt get water in it i made a hole in the rubber grommet and threaded the cable through then used some silicon to seal it up completely. From there i ran the cable through 10mm flexible conduit and cable-tied it to the existing wires all the way to the battery.
