WM CAPRICE JUNK,, LS2 MOST OVER RATED ENGINE , HOLDEN DISHES UP THIS....... SO LONG SUCKERS
English caprice
45
Bray park
Wm caprice
1ST MISTAKE BUYING A HOLDEN, I READ SOMEWEAR THAT THE LS SERIES MOTORS ARE REGARED AS ONE TH E THE BEST MOTORS OF ALL TIME...... HAD THE HEAP OF **** FOR 6 MONTHS , AFM 6.0L V8 , SLUGISH AT BEST, (WEIGHT?) THIS THIS THROWS OUT WARNING CODES LIKE THERE IS NOT TOMORROW, AND DISAPPER OVER NIGHT,??
MY FAV THE STABILITY CONTROL OFF ONE, AND IT STARTS RUNING LIKE A PIECE OF CRUD, BEEPING , CHECK THIS REPLACE THIS ...
FUKEN DONE THAT BUT NAR,, STILL ****
ITLL BE IN THE PINE RIVER SOON
figjam
Donating Member
Far Kurnell
FJ
Meh. So you bought a piece of junk. Not happy, Jan ? Tell Qld Consumer Affairs, or some-one else who cares.
VFSV6FORME
74
WN Caprice V 6.0L, VE Anniversity V6 Series 1
Great first post
What a Wanker!!! For starters WM Caprice did not come with LS2. ooooooh No did you buy the Car from ????? ????? Pine Rivers at Lawnton See you live a Bray Park which is 2 K away. If I'm Correct thats the car yard that sell you a V8 with 4 Pipes like a typicle VE or VF and yet only one is connected to the V6 Engine. Should have done you Home work First.
lout
60
Langwarrin Victoria
aka
i bought this real cheap bargain car and it's no good
must be someone elses fault
woteva
NEED 4 SPEED
Adelaide S.A.
Ginger Beer
Dunnydoore
Did you test drive the car?
Are all the bad things that happen to you the fault of others?
Do you get butt hurt often?
If the answers to any of these questions is yes the you need help.
The world is out to get you and you cannot be held to account for your actions.
Don't forget to collect your participation price, and don't let the door hit you on the way out.
VS 5.0
Don;t worry @English caprice , with Qld missing its opportunity to keep the border closed today, you will likely be in lock down again in a few short weeks so won't need a car.
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Unless it's HSV ,it wouldn't have a LS2,it's either L98,L77 or LS3...
Also,your info is correct,LS2 is one of the best HOLDEN V8s around..
