wm statesman 2006 head unit removal
Trentl
Bacchus Marsh
Wm STATESMAN 2006 V6
i have purchased a wm statesman 2006 model and i want to remove the head unit to upgrade the sound system, what to u have to undo to remove the lcd headunit ??
Troy711
Retired Old Fart
Canberra, ACT
forums.justcommodores.com.au
2011 Mitsubishi Pajero GLS
I doubt you could remove it all together because it operates the climate control and everything else associated with the LCD. I'd say you would have to mount it elsewhere or get some low level outputs for the factory unit.
db_notso
diagnostic technician...
sunshine coast, qld
vt v6, mods(susp brakesetc...)
remove facia
glove box out
bothe left and right lower front trims beside unit
aerial on left side
clamp type connector right side
four ten mm on front of radio
= no hvac
NORTI
Radelaide
Wildtrak
would also = illegal, as no demisters?
jeff47
jeff47
wm statesman 6.0 lt
also no replacement but can upgrade with amps and speakers as i did with rockford system
5utto
VE Berlina
WM Radio Unit in VE Berlina
I understand that this thread is over a month old.
Currently have changed all of the pplastics in my MY07 Berlina to Calais silver, last thing to do is the radio. Found an WM Statemans one on eBay. Has anybody managed to fit one of these to a VE?
Already have the plastic surround from Holden but quickly stipped the dash and centre consol down and it appears I'll be short of some screw holes.
Any assistance would be great.
