WTB Small Relay/Fuse box, with only main fuse.
ShawtyNate
In the feels.
I need the relay box from under the hood, its the one that says ABS, FAN, MAIN, HD LAMP or something and BLOWER.
Does anyone have a spare one, all i need is the box with the MAIN fuse in it.
Thanks
Nate
Cracka
Banned :P
Croydon
Old Sneakers
take a pair of side cutters and head to the wreckers, find a base model poverty pack that no one will miss and cut it off. Then to avoid being charged for the whole loom but to ensure your not a thief grab a handfull of random rubbish from the ground and pay $5.00 - $10.00 for that
The only reason I say this, is because i'm fairly sure its part of the main loom and cannot simply be unplugged or pulled off easily.
What happened to yours? fire?
ShawtyNate
In the feels.
It's the little box, and it can be un bolted.
ShawtyNate
In the feels.
nah one of my mates were helping me see why my car wasnt starting, we pulled out all but the main fuses and replaced them and my mate dropped the hammer and crumled it.
m62vpute
Country Vic
VP MANUAL S/C 3.8 UTE
For the amount of effort in finding another small fuse box it will be heaps easier to go out and just buy another fuse to replace the 1 that has been broken
turmoil117
Donating Member
33
Armadale
Vs berlina
Isn't it just bolted On? I mean the whole point of a fuse is to
Protect the wiring, if the fuse blows and you have to replace the whole
Box that would seem a little pointless
Brett_jjj
Tamworth NSW
vs commodore
The main 60 amp fusible link has a small bolt holding it in,whereas the others either side of it will just pull straight out..This small bolt is located just down under the fusible link holder,theres a small plastic door/flap that opens outwards and theres the bolt up inside there.You can follow the main positive wire where it goes from the positive battery terminal to the fusible links etc as it also goes straight to this same bolt, it joins up to the main 60A fusible link in there behind the plastic flap.
BowTie
Jindabyne
Vr vt
There's actually two 10mm bolts holding the spades on either side of the box.
A small flathead will lift the flaps to remove the bolts and slide the fuse out.
