WTB Small Relay/Fuse box, with only main fuse.
Brett_jjj
Tamworth NSW
vs commodore
At the point of the screwdriver in the pic is the bolt that holds the main yellow 60 amp fusible link in its holder.Just undo this bolt and the main 60 amp fusible link can be pulled out and replaced..Sorry the pic isnt a bit clearer..
ShawtyNate
In the feels.
what kind of fuse is it, male or female and can someone fine me one?
Brett_jjj
Tamworth NSW
vs commodore
You have to buy this specific fusible link,they are not like the common type of fuses that most cars use.You will probably have to see holden to get one.....
EDIT:Heres a link to a couple at supercheap auto..Im not sure if these will fit as the one you need has the bolt through it holding it in the holder..But it gives you an idea of what to look for..
The ebay one has the holes through its legs for the bolt,so Id say its the one you need..
---http://www.supercheapauto.com.au/online-store/products/SCA-Automotive-Fuse-Link-Female-60-Amp-Yellow.aspx?pid=120418#Description---
---http://www.supercheapauto.com.au/online-store/products/SCA-Automotive-Fuse-Link-Male-60-Amp-Yellow.aspx?pid=120419#Description---
---http://www.ebay.com.au/itm/Fusible-Fuse-Link-Male-Straight-Leg-Yellow-60-Amp-/180667867222?pt=AU_Car_Parts_Accessories&hash=item2a10a4e056---
BowTie
Jindabyne
Vr vt
Male - Products - Narva
You need the 60A version which is part# 53160BL (1).
Note the bolt holes in both blades.
Changed one only a week ago. Any auto shop stocking narva should have it for $5-7
Daniel Eklom
30
Vx l67 commodore spac
Might think I’m stupid but can anyone tell me what wire runs to the 60 amp engine fuse I’m left with 2 wires after engine change and one gose to earth and one is for engine 60 amp fuse ????
