Wtf @ wiring doors for power windows!!!
OzJD
Bankstown, NSW
jeltel.com.au
2010 Holden Caprice V II (V8)
was it the front or rear door?
It's common in the front doors, but I didn't think it existed in the back ones
(Well - its not in the back door, just inside the car - but still part of the loom.
Zuicider
Banned
Stonedville
Set of thongs
front doors i also have a set of electric winows mechs from a vr seires one executive and looms so should be there,
OzJD
Bankstown, NSW
jeltel.com.au
Mmm just wired in the back window, and its not doing to well.
Seems to be gripping on the old tracks a bit too much... might try some spray lube (silicone) or whatever it's called.
Also might check the earth, since when I tested it (straight after install) it was perfect :-s
ephect
Donating Member
VS Acclaim V6
is this true? im going to check my exec today? its got abs
dont know 100% but check my post #8.. if you have them you have the wiring
spd_dmn
1994 VR Exec, 5.0L BT1
things to check if you have the wiring..
2 metal pins in fuse 5 (i believe its no5)
5 metal pins where the pwr window relay goes
plugs under the console, beneath the stereo.
plugs in the B-piller, which is for the rear doors
if you have them u can install power windows without much hassle, i think there is a couple of threads with good info in the electrics section or it could have been in this section
^^^ This is correct. ^^^
I installed elec window in my VR not long ago. I already had the main wiring loom and the 2 front door looms run through the car from factory. Only thing I had to do was swap all 4 manual regs with the elec window regs, then swap the rear door wiring looms with elec window wiring looms. Plug it all in, then plug the switches in. Get new relays for the elec windows, they plug in under the dash, beside the steering rack.
Also you will have to change the BCM otherwise the drivers window won't work. I just bypassed it with the help of a little tut on **************** as it was alot easier and cheaper ;)
