Fog Lights Loom?
BigBoss
VE Omega
Hey Lads,
I'm in the process of installing fog lights in to my Omega, I believe I have it all worked out except for the location of where the fog light wires connect to the relay (located in the fuse box). Can anyone help me find where this wiring loom is located?
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Is the foglight relay fitted? Should be relay R5, also Fuse F4 15A.
If it is fitted remove the relay and ensure theres terminals in all 4 positions.
The connector for the relay harness is an 8 pin connector that should be behind the front bumper drivers side if its there at all.
BigBoss
VE Omega
Just checked and there are no terminals in relay R5, where does this leave me?
Is it possible to get the signal for a relay out of the BCM?
itsArthurKomar
sexy beast
ya asss
super awesome time machine
just obtain a wiring harness from JHP and go to an auto elec and he will inbreed it for u :p ( good choise of words/// i know lol)
RiCeY
Australia
May be able to get the harness from parts and fit it yourself?
BigBoss
VE Omega
Thanks Arthur and RiCeY I will look in to that, cheers :)
BigBoss
VE Omega
I would definitely like to fit it myself, Any idea where the the wiring harness would plug in to RiCeY?
EDIT:
Hey RiCeY I found this (posted by you) in another thread.
So does this mean I'm looking for a dark green (D-GM) and a white (WH) wire coming out of my BCM?
RiCeY
Australia
Yes dark green with white trace will be the one to connect to the relay to activate it.
Not sure if BCMs have luxury levels, if so that wire may not even be there...
BigBoss
VE Omega
Oh... Ok then how would i go about looking for this wire?
