HSV08
- Jan 8, 2012
- 245
- 3
- 18
- Location
- Auckland New Zealand
- VT HSV SENATOR SIGNATURE
So the senator is in the garage awaiting the rebuild.
So what i have planned to do is:-
-Acid dip block and plenum and possibly crank.
- Flat top pistons and rings
- A crane type 286 spec grind with a 110lsa at .500" lift
- a slight head porting
- deck the block to zero
-new hydraulic roller lifters
-new crank bearings and cam bearings
- plus all your normal extra's ( head gaskets plenum gaskets sump gaskets oil etc)
Now a few qeustions....
With the cam and ecu, do you think it will be ok to run in motor on the standard 5l computer and 98octane until i can sort tune out?
I was also thinking of a 276 but love the lopey idle of the 286 so thinking that maybe the better option
What valve springs do you recommend?
is it wise to deck to zero with the flat tops?
What else would you recommend also getting or doing engine wise ( high stall will be coming later on)
Im not wanting an all out power monster, but something some what streetable with power in the range of 2500 to 3000 up and some good hard torque (without going stroker or charged) and something that is nice and grumpy at idle but not going to be a too much of a pig down low, but im willing to sacrifice some as its not my daily.
Ideas and recommendations?
