304 1500 klm compression check
tim_pato
Tamworth
daily-5.0 5spd vr ss clubodore, project-74 lh rana
Motor had 256 thou on it ,not terribly well looked after. Cylinder was only honed, deburred with a ridge reamer, precision engineering Hypatec flat top pistons, I reseated the Valves by hand, first attempt at a rebuild.I've done 1500 klms since I rebuilt the motor. Compression test is as follows on psi from cylinder 1 not in firing order....
174
170
163
163
162
178
165
165.
The motor is fairly chewing the oil. 1.5 litres over the 1500 klms. No valve stem seals on the inlet valves. There Ferrea Valves and didn't have seals on them when I dismantled it or anywhere to put them. Thoughts?
Opinions please.
Deuce
Super Stock
'94 VR SS V8
174
170
163
163
162
178
165
165.
Opinions please.
I had a previous combo running without valve seals.
Used about 1.5l over about 7000kms.
So I would blame something else for your oil usage. Although; how tight were the stems to guides?
tim_pato
Tamworth
I don't have much to compare them to, they seemed ok. When I placed one finger over the valve stem hole and withdrew the valves (clean no oil)the vacume was noticeable.
How long does it usually take the rings to bed in?
Immortality
Staff member
Sth Auck, NZ
How did you bed in the new rings?
Put in some full mineral oil, fill the car full of heavy mates or better yet some fat bottom girls and go find some big hills, lock it in 2nd gear and get some load on those rings by driving up those big hills and then do what ever you do with fat bottom girls :D
It's probably a touch more variation than I'd like on the compression test but best to worst is about 10% difference which still isn't too bad although with new pistons and rings i'd like to see it more consistent.
EYY
VS Statesman
Smoke on startup is usually caused by worn valve guides or valve stem seals. How long does it take to disappear?
If it smokes for a few minutes I'd be more inclined to say that it's an issue with rings sealing
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
where did you put all the ring gaps when you assembled the engine?? ive seen people line them all up so theres a direct space for oil to flow up from the crankcase instead of spreading all the gaps out like they should
383 hatch
41
Cowes, Phillip Island
Although I do set the rings apart during assembly, I really don't think it makes a difference. The rings turn during operation, so they can line up at anytime anyway.
tim_pato
Tamworth
Ok, cam run in procedure with penrite running in oil. Fresh filter and penrite running in oil. 300 klm around town.fresh filter and penrite hpr 30 full mineral oil. 500klms in the new England ranges with a boot FULL of hand tools (heavy) and 2 blokes. Then 500klms town and highway use. Rings where aligned around so that none lined up and evenly spaced. Oil on startup isn't always present most of the time it's not there. When it is it either goes away quickly mostly, occasionally it lingers for a few revs.
