MikeC
- Jan 10, 2010
- 1,126
- 483
- 83
- VQ Statesman
The ALDL is a loose 6 pin plug hanging from the main loom that's hidden to the left of the glove box. It will have a row of 4 connectors with 2 connectors under it separated by a clip that's meant to hold the plug from a GM Tech 1.
You need to connect the two pins on the right side- a black wire and a black/white wire. I use a bent paperclip for this.
With the ignition on and the engine on it will flash a code through the check engine light. These flashes will tell you the state of the faults stored in the ECM.
Note for a 5L there is no specific flash code for the A/C fan but if the ALDL terminal is earthed the A/C fan should come on. I don't know exactly what happens with a V6 but I would suspect all fans should come on.
