MikeC
- Jan 10, 2010
- 1,126
- 483
- 83
- VQ Statesman
It won't have a speedo cable. The speed sensor is a round black plug thing at the back of the transmission with three wires coming out of it, make sure its white plug is plugged in to the wiring harness. The plug connectors are 3 sets of plugs at the back of the dash cluster- to remove the cluster you need to follow the instructions on this forum. You have to be methodical and careful of the old plastic.
I have a level 3 cluster and i find I don't have to remove the steering wheel if I turn the wheel so it's pointing down from its normal position and the bevel on the hub is at the top. The cluster can then be slid over it and out to the left.
Break, clean with contact cleaner and reconnect all the cluster plugs. Make sure all the plugs are re fitted tightly.
Don't worry about the questions- we all had to start somewhere with our first cars.
