acarmody
Donati..Whoa Green
- Apr 29, 2007
- 5,920
- 56
- 48
- Location
- Brisbane
- VX Berlina
OK I've been crunching numbers and no matter how I work it, its going to be bloody close. I drew up a template and spent ages working out how to make these fit and this is the best I can come up with. Now if as above I screw the far ends of the sub into the side walls I will have 350mm square to play with in the middle of the box. Now it doesn't matter if the side of the flares overlaps the 350mm because the inside of the box has plenty of sideways space (because sub is narrower at rear), and in the front it can overlap the frame and the rubber suspension without problems right? But it can't overlap the roof and floor of the box on the inside but it can on the outside. So looking at the diagram below (the bottom and side labels are purely for reference so you can visualize what the hell I'm saying) if I sand of the bottom 1cm of the flare on each sub and put the flat against the roof/floor of the box, AND I shave a few millimetres where the two ports meet on both the inside and the outside, it should fit.
Does this make sense to you, and can you see any glaring holes? Apart from the fact the ports holes in baffle will need to be millimetre perfect (I'm getting cabinet maker to cut holes hopefully).
