[VIC] Getting my reflection in the paint back after respirating
Joopjbc89
34
Hampton park
2009 holden calais
So I recently resprayed areas of my calais where there was some nasty scratches
I used the usual
Sand paper
Prime
Paint
Clear coat and cut and polish
But still didn’t get the reflection in the paint work
Can anyone help
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Did you wet sand it in between paint and cut and polish ?
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Rub back with1500 grit wet and dry using plenty of water with a bit of dishwashing detergent to lubricate .sand until surface is smooth , keep checking as you sand and use plenty of water
losh1971
North Tas
VE Series I SS Ute
I normally start with 800, then 1200 then 2000 then 3000 with lots of water. You can get away with going up to 2000 but 3000 means buffing is quick. Also it will depend on the paint you use. If 2 pac that is ok, but if using acrylic it's best to let it harden for 5 - 6 weeks then buff. The wet rubbing can be done sooner. Some online tutorials say it's better to buff 1-2 day old acrylic. I tried this and got swirl marks the first time. Last time I left it for 8 weeks and it came up beautiful.
Joopjbc89
34
Hampton park
2009 holden calais
Thanks for the help
So when I sand it down get it smooth again do I apply clear coat again or just leave it? Like what steps do I do to get the perfect reflection finish?
losh1971
North Tas
VE Series I SS Ute
Depends how good you were at applying the clear. If it has no orange peel at all then you might be ok. But it takes some skill to apply it nice and wet and not get runs. If you have a thin coat with orange peel it will need more clear. If you have a thick coat you might be ok to rub it down enough ready for the buff. Hard to say without looking at your work.
Joopjbc89
34
Hampton park
2009 holden calais
Joopjbc89
34
Hampton park
2009 holden calais
I’ll take another pic tomorrow when it’s daylight but that was before I buffed it but doesn’t look much different
