||| hi_ryder's VP Calais LS1
ephect
Donating Member
VS Acclaim V6
Mate that come up sweet
383 hatch
41
Cowes, Phillip Island
As far as I'm aware all GM vehicles have a 0-90 ohm sender, so you should be able to ditch the VP fuel pump and sender all together and plate the hole over. Then all you need to do is cut a hole in the top of the tank, weld the ring on then drop the VT module straight in. Job done.
Terminal
Stealth
92 VP Calais
That coil relocation plate seems to do the job, if you did put more love into it I think it would look great, as it stands now it isn't hideous.
Thanks for the pics, My main problem is actually underneath where the header pipes straighten out and run parallel to the frame. Do you have any issues down there?
hi_ryder
Donating Member
Pascoe Vale South, MEL
ok guess that settles that.... ill see if i can track down a long range tank.
ahhhh, ok ill see if i can take pics of that tomorrow
hi_ryder
Donating Member
passenger side, ill round off all the 90 degree angles, and hollow out the blacked areas. driver side will follow this design... think im going to wrinkle paint these so's i can hide the arts and crafts look.... tried to line them up best i could to the other side. me needs to buy a dremel me thinks....
hi_ryder
Donating Member
terminal no need for me to take pics of the exhaust under the car. the pipes are hard up against the fuel and brakes lines. theyll all have to be moved...
Terminal
Stealth
92 VP Calais
Ok so I guess i'm not the only one. Haven't seen it mentioned though in any of the forum threads I read through over the time i've been planning/undertaking the project.
Also that relocation plate looks good, if you could keep/make any template i'd love to make my own.
