VXcalais, easies way for you would be to jusck from the front of the car under the crssmemeber (not the motor) and put the stands under the jacking points.
As for everything else, couple of things ill add to the details of an oil change / service
Check all fluids under the hood, brake fluid level and condition, P/S fluid, top up your wahser bottle, check coolant level and condition, check hoses anf fuel lines for leaks, on ECOTECS check the vacuum line from the bottom of the trottle body hasnt come unplugged (common problem) When jacking the car to undo the sump plug - NEVER GET UNDER A CAR THAT IS ONLY SUPPORTED BY A JACK - ALLWAYS suuport the car with no compresable stands. Drain the oil while the engine is Hot, not cold like some people say to. When refitting the oil filter, you only tighten it 2/3rds of a turn once the gasket makes contact with the housing face, this doesnt seem very tight, i know, but thats how tight it should be, and it shouldnt leak like this, if you do it too tight, then you will need a screwdriver to get it off next time. No need to pour a bit of oil into the motor before you put the plug back in, just put the plug in and save yourself some $$ you know that the oil will drain, you just drained about 4 and half liters out didnt you :whistling. When you fill the eng, it has been said that an ecotec takes 4.8 - 5.0 L So as a good starting point, put in 4.5, then start the car, watch and make sure the oil press light goes out, then turn off the eng, and wait about a minute, then recheck the oil, and top up to full mark, do not overfill, this will create extra friction between the oil and crank counter weights, which will hamper power, performance, and fuel economy.
Best way for sump plug, is to use the ring end of a 3/4 ring/open end spanner, with the angle of the spanner pointing towards the sump, and then thump it with the palm of your hand while holding it on the plug with your other hand, this is how i always do it at work, but then again, i get to stand on my feet at full height while im under the car, which helps too i guess lol
