wazza675
- May 2, 2012
- 101
- 0
- 16
- Location
- Melbourne
- VE Omega Sportwagon
Thanks for the write-up - it made it very easy and straight forwards.
A few notes from my experience...
Dunno when the fluid was last changed. I bought the car at 220k from my father-in-law who is a mechanic. It's now got 385k and I've never done it before, nor have I asked that it be done!!
I jacked the car up from near where you put the jack to change a tyre on the driver's front. I then put an axle stand under the cross-member near the sump as 'security' in case the new jack failed.
I undid about 6 or 8 nuts on the rear passenger side (lowest) expecting the fluid to come out pretty readily but it took a screw-driver to lightly pry the pan a little before it began to weep. I then worked towards the highest point allowing the fluid to flow out. I sloshed the fluid till the pan was probably half empty after which I dropped it onto a crate so I didn't drop it (given the awkward position I was lying in). Given the torque settings suggested above, I think mine were less as they were hardly done up at all. The engine cases on the bikes I've worked on are 8-10Nm and they still take a bit to crack but these bolts were almost finger tight.
I ended up with about 4L of fluid in the drop pan with some still in the trans pan that I dropped straight into the oil drum without measuring (idiot). I cleaned the pan up with turps, rags and a scraper. then I took out the filter... REMEMBER IT STILL HAS FLUID IN IT THAT HASN'T DRAINED OUT... that ended up on the tarp and carpet under the car!!
I replaced the filter without changing the O-ring as suggested by most. When I took the gasket out from the box, it didn't want to sit flat initially which made it impossible to seat it correctly to re-fit. In the end, I used 4 small cable ties in the centre of each side VERY LOOSELY to hold it in place, which allowed me to put in the rest of the bolts, cut out the ties and then put the last 4 bolts in. I'd suggest that the gasket be laid out flat for 24hrs before you do the job or use the cable ties. It helped a lot given the confined access and awkward body position. Working around the pan I slowly built up the amount of torque on each bolt till they were at 11Nm.
After re-filling the trans, I was left with about 400mL of fluid from a 5L container of Bursons brand Dex3.
Remember to wear safety glasses... I know it sounds like common sense but I've got drips through my hair and crud in my eyes, even with them on.
In the end, I think it took about 3hrs including a thrash around the block to check my handi-work but I was being cautious.
Thanks again for the advice above. Next is the same job on the VE.
