Bizmark
I'd replace them if you can see any visible cracks... From seeing the difference it made to my VR, it seems any leaks there play hell with fuel regulation...
EDIT: Plus, it's $3 a metre for the vacuum hose!
They're tiny tiny cracks, which you cant see unless you pull on the hose, not sure how deep they go either.
Where'd you find the hose for $3 a metre? If i can find hose that cheap, i may as well slice off the old hose and be able to check the fuel pressure reg properly.
