Please help me
v6theworld
19
Qld
Vs
Hi guys I'm relatively new to this and I've just brought my first car (a VS series 2 commodore 1996) I've done a fair bit of work on her myself. My odometer hasn't worked since I brought it and I was told by a mechanic it is most likely a set of gears that run the odometer, I've replaced them and it still doesn't work. Any help?
VS 5.0
When I replaced mine they didn't work straight away.
I took the gauge cluster out again and wound it forward a couple of kms and it was good to go.
Also check that there isn't a small piece of cog from the old gear stuck in there.
Draimond
VS V6 Executive
Not strictly related to your question, but I seem to remember that one of the things that'll snap the plastic gear is hitting the trip reset button while moving.
It's been over a decade since I've done the od gears... Aren't they meant to have some kinda plastic safe grease on them too.
woteva
NEED 4 SPEED
Adelaide S.A.
Were your old gears busted ?
Here is a before pic from a VS cluster i did last year.
v6theworld
19
Qld
Vs
Yeah I did put some grease on it.
v6theworld
19
Qld
Vs
Just pulled her apart again, there wassnt any old teeth lodged so I wound her forward then put her back in, the trip meter worked for a bit then stopped working the odometer didn't work at any point
ephect
Donating Member
VS Acclaim V6
Did you replace the gear or see that it was missing teeth?
