I spoke to our local engine builders and he said polishing ports will make a diff. He told me that an engine place in Melb did the tests. Having said that he also said the increase in HP just through polishing was minor and not worth it because of the time it takes. But fitting larger valves made a noticeable difference.
Hi losh1971,
Thanks for your reply, and Yes your engine builder is correct but?
I'm not doing the port and polish for horse power,
I am trying to create a more efficent airflow into the intake manifold for fuel efficiency.
I want to see what I can do to improve the vehicles fuel efficiency without spending bucket loads of money.
I am starting at the throttle body and looking at what I can do there?
I'll then making way into the Plenum.
Then I'll move to the Inlet Manifold.
I will add a 12mm or 25mm MACE Inlet Manifold Insulator spacer but I have not decided which one yet? Because I have been told by a few friends that if I add the 25mm Inlet Manifold Insulator it may hit the bonnet when I put the engine cover back on and I want it to look original. So? I think I have to think about it for a little while as the 25mm is more expensive as well, and I want to keep the costs down as much as possible.
A friend of mine added a 12mm MACE spacer to his Plenum and got a noticeable change immediately, it was more responsive and he said? He just has to touch the excelerator now, where before he had to push the excelerator a little. He has not port and polished anything, and he has not tested it either, to see if there is an increase in horse power, but I don't think he cares hahahaha, it put a smile on his face so that is just as good. So now? I want to do it for myself and see if I can improve it without spending a lot of money in the process, just my time and effort and a little money here and there.
Also? I think he should have added the Insulator to the Manifold and not the Plenum, but that's just my way of thinking, it could work just the same, But maybe I can add both? I will see? At a $135 for the 12mm and $185 for the 25mm, I really have to think about it? Or run one and add the other later? We will see.
But anyway? I'm having fun in the process and it's not costing me an arm and leg, Plus I hope someone eles can get a benifit out of my experiment.
Also? I another thing that caught my interest was the High Voltage Coil Packs? The feedback I am reading seems to suggest there is a benfit there as well? But I really have to consider those as they are very expensive, and of course in combination wiith all the other changes I make.
Anyway, enough ranting and raving.
Hopefully I can do some testing, but time is an issue.
I am trying to achieve all this with as little cost as possible.
Doing the work myself, and as I mentioned before, this is not about horse power, it's aboy fuel efficiency. I do realise they I may gain a little more horse power but I really don't think it would be worth testing for as it would only be around 5-10 kw and that's nothing to write home about, although I will be happy. but other would not be, hahahaha All good.
