Irukanji
101% Lunacy
- Jan 27, 2012
- 111
- 5
- 18
- Age
- 33
- Location
- Heathcote
- 2000 VT Exec LS1 A4
I have no evidential experience, but common sense tells me a large plenum chamber will improve acceleration. Now, before you jump on my nuts and say "prove it", think of it this way.
You put your foot on the accelerator, but there is no oxygen. The revs climb slowly, it slips into second(auto), and then your acceleration is gone because your trying to get acceleration out of a gearing designed for a higher speed.
Now, you increase the size of the plenum chamber, and you have the air available. Ram air intakes(think ramjets, not those cosmetic scoops) are designed to deliver as much air as possible to the combustion chamber, and the sensors adjust accordingly. Increasing the size of the throttle body allows more air to flow, but there will still be a slight delay between opening and air actually flowing past in the required volumes.
However, insulating the plenum isn't required. It's made from thin aluminium, you have a large air flow going through it, and so the temperature should sit around the same. Besides, the bonnet has insulation which traps heat, so the plenum is going to get hot regardless of what happens. The heads(which the manifold bolts to) are cooled by water(or glycol + water or whatever you want really), and the average operating temperature is around 120 Celsius with a considerable amount of force. So you could run a faster water pump and a cooler thermostat(I've seen 82C being the standard upgrade), which will bring the temperature down more than a piece of silicone will.
But definitely a bigger plenum. Hell, for 50 bucks and a weekend, you could braze together some sheet metal into a new plenum, with none of the dead air pockets, and all of the space you want inside of it. But that requires effort, and it's going to be easier to undo a half dozen bolts and stick a piece of precut rubber in there and then bolt it back together.
Besides, I'm willing to bet the single plenum spacer gives better gains, theoretically, than any pod filter yet people still fawn over them.
Not defending MACE or anybody else, just offering my 2 cents.
