Pod Filter with CAI on a VR/VS
savage1987
Donating Member
www.facebook.com
Should be legal I think, pod filters themselves aren't illegal as far as I understand . . . just that most people don't mount them properly. A sealed pod should be fine I'm fairly sure...
Sam
System
Donating Member
2005 VZ commodore exec
thats right, most people get busted because they dont clamp the pod down to the man body, if u do that- or as this tut shows 'hide' it, u'll b fine
savage1987
Donating Member
www.facebook.com
yep, the unsupported pod is what'll run you into trouble. Perhaps they're at a risk of falling off under cornering or something... don't know, just that if you use an appropriate bracket for support you'll generally be OK.
DannyboyDS
Just hand me the pliers.
39
VS Berlina
any time, I would like to once agian point out AbbaFan is correct a Naturally aspirated vehicle needs nothing more then a high flow panel filter and a cool air intake, however as pods can be quite cheap to come by, this can be a cheap workaround.
I am currently running a high flow panel filter and CAI and its the best intake system ive used yet.
Cobez
LS-EXUAL
39
2004 S2 VY SS Ute
I have on my car, what abbafan said earlier (pod mounted in my front bar where it catches the full force of the air through my VP senator front bar. It's all bolted up properley to the bottom of the airbox. Works a bloody treat. The filter just needs to be cleaned a bit more regulary.
craig_maxfield
VR Berlina HSV
is it true that if you move the air temp sensor that too the air box it will make the car run betteR?
DannyboyDS
39
VS Berlina
the airtemp sensor is in the airbox. best to leave the airtemp sensor where it is, or if you do move it put it somewhere else along the plenum pipe, it is important to control the correct air/fuel ratio, you wouldn't want to run rich and waste fuel for possibly less power.
