removing a rounded sump plug
Discussion in 'General Discussion' started by idb, Aug 31, 2010.
  1. idb
    idb New Member
    holden vx s m5
    hey all i just got vx s pack and i thought i mite change its oil and i found that da old owner has rounded the sump plug. I tryed removing it with every thing i can think of but still no luck Can any one here give me some clues to removing it or is there any tools which are good at removing rounded off bolts thanks for reading this and your input idb
  2. shifty6
    shifty6 New Member
    VS Exec 5spd
    get some inox and some screw extractors.
  3. Rusty
    Rusty ٩(-̮̮̃•̃)۶
    Queensland
    Vt with VU/VZ bits
    If desperate to get it off and your obviously replacing it anyway. Drill a drillbit sideways through the top of the sump and remove drill leaving the drillbit through the sump. . Then use hammer on the drillbit as leverage.
    Other option i often thought about was welding a small rod or chunk of metal onto the sump and using that as leverage. Never tested it so you'll probably blow up if you try it.
    Good luck mate
  4. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    Try using a pair of stilsons , They are a bit like an adjustable spanner .The more leveridge you use to undo the nut , the more they clamp onto it which reduces slipping off the nut and rounding it off even more.
  5. Lumps of cheese
    Lumps of cheese welcome to the machine
    Warrnambool
    Cammed calais, 4x4 hilux, 03 monaro, 08 FXDC
    Yep, stilsons are good. If all else fails tack weld a nut on the plug to get it off.
  6. Stretchomatic
    Stretchomatic New Member
    Ardlethan, NSW
    86 VL Berlina M5
    stilsons or vicegrips...the way to go!
  7. excalibur
    excalibur New Member
    Hiding in WA somewhere
    VP SS
    +1 best options
  8. maldotcom2
    maldotcom2 New Member
    Cammed mafless VS Calais 5-speed.
    Surely you can get it off with a pair of vice grips.
  9. undersuspicion
    undersuspicion Now That's How We Roll!
    Vy SV8 Series 2
    vice grips or a small socket and smash it on with a hammer.. You wont be able to use the socket again though id expect.
  10. IBLOWN
    IBLOWN Active Member
    VS V6 TwinTurbo/'11 WM CapriceV/Hayabusa
    Use a hammer and chisel, hit it anti clockwise and it will come off. Do not go hitting a drill bit with a hammer if you dont want bits of drill in you skin. Do not smash a socket on it as you will most probably crack the sump as its only think cast aluminium.
    Doubt vice grips or stillsons will get it off either. It needs a quick sharp tap to crack it.
    Just think about it. How tight is it on there if the last owner rounded the head off???? Bloody tight.
  11. kcpwns
    kcpwns Kicker - Livin' Loud :)
    Shepparton
    VY V6 Equipe
    i had the same problem on my vy...i found welding a nut onto the existing sump nut was the easiest way :)
    make sure ya dont earth out the welder near anything electronic on the car tho..
  12. soop
    soop Banned
    Smithton, Tasmania.
    2003 SS Commodore Series II
    It could be loose as a goose. I've seen wallies round of loose nuts by using the wrong tools. Once they're rounded they might as well be welded in though.
  13. idb
    idb New Member
    holden vx s m5
    thanks evey one for your help ill give it a go on da weekend
  14. maldotcom2
    You could also use a dremel or similar tool to flatten off 2 sides of it so you can get the vice grips onto it.
  15. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    Thats a good idea ,or grind the sides down so you can fit a spanner on . If the vice grips slip then your back where you started
  16. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Vice grips or Stilsons would be just about guarenteed to work, it can't be THAT tight or it would have just stripped the thread.
  17. DevilDRake
    DevilDRake Braaaap
    Skye
    2006 VZ SS 6L Ute
    ^ In which case you'd need to re-tap the thread also =\...
    But yeah, vice grips~!
  18. Swordsy
    Swordsy mmmm beer....
    Newi NSW
    VUII Maloo R8 - HX Tonner - XJR1200 - XR450R
    Vice grips slip and you bash your hand. Stilsons are the way to go.
  19. VzVzVz
    VzVzVz New Member
    Port Melbourne
    VZ S ute
    get the smaller size down socket and hammer it on. Or use a single hex socket of the same size instead. If that fails, use a pair of vicegrips and squeeze the tits off the c*nt.
  20. Commydoor
    Commydoor born in the FB era
    Beresfield, NSW.
    Vr Ss Blown
    replace the engine
