[VZ] Save your SS seat bolsters from getting squashed
derrro
haha tough
VZ MY06 SS
Yep - I don't need to change mine around again, but I will take out the driver's seat and disassemble it to show u guys how it's done. BTW the LX8 has identical seat bases to VZ SS so it will be easy as for you.
RIP 05
WA Perth
VZ SSZ sedan
Cheers derro, just want to see whats involved before i take it on. How long do you reckon it takes for the swap over?
m1lky
Auckland
VY SS
I'll do mine too with your tut. Cheers mate
VZ_SS
Maitland NSW
VZ SS
I did the same thing on my car. Good post to the op
derrro
haha tough
VZ MY06 SS
I'd give yourself about 3 hrs, including doing a QA after
badnuz
new zealand
VE GTS #0028
great idea... hmmm a few spare hours this weekend that should be spent on the house but meh, car needs some luvin :)
tezza
VX SS
Its pretty straight forward once the base and seat back are unscrewed. Held on just by the plastic stops.
I did this on my SS when it had some play in the base. Although i might price a new seat foam, after 11 years she's a bit worn.
derrro
haha tough
VZ MY06 SS
PIcs of seat removal
Hey, have got round to showing you boys how to remove the seat from your SS. As I have already done this procedure before and I don't want to pull both of my seats out again, I have focussed on the driver's seat (the passenger one is the same, but less involved).
1) You need to remove the plastic trim covering. There is a phillips head screw under the petrol flap release. Undo this.
2) Snap off the clip on parts:
3) Disconnect the electrical stuff (ONCE THIS IS DONE DO NOT KEY ON - YOU WILL GET AN AIRBAG FAULT CODE):
4) Ease the long trim cover over the petrol release lever by pulling up on the lever whilst sliding the trim off:
5) Remove the rest of the trim covering and check that you have disconnected the seat electrics:
6) Undo the seat bolts:
7) Slide the seat out back first:
8) Good chave to clean it up a bit:
9) On the removed seat pop off the recliner knob (if you have one) with a screwdriver and remove:
Klick!
10) Remove the side trim from the seat. This is held on by a combo of screws and clips. One of the screws is UNDER the seat:
11) Disconnect the seat electrics:
12) Remove the trim cover at the other side of the seat:
13) Unthread the cable leading up to the side airbag (if you have one):
14) Unbolt the two bolts holding the base of the seat to the back bit on both sides:
15) Separate the two sections carefully:
16) Turn the base over on a soft surface and unclip the leather/cloth. There are 4 plastic clips you need to un hook from the seat:
17) Gently remove the foam, leaving the leather on it. Move on to the next seat and do everything you've done above. When swapping the seat base covers from seat to seat, be careful to insert the foam OVER the metal former. The former must be in the foam pocket, NOT NEXT TO IT.
18) Re installation is the is the reverse of removal. To put the seat winder back on put it in place and hit it home with the palm of your hand:
19) Put the seat back in but don't tighten it fully:
20) Sit in the seat and test that the forward and backward movement is ok.
21) Get out and tighten all the bolts and check for proper operation of the seat again. If it's a bit slow snapping into place, repeat the step above.
22) Slide the trim back into position. With the petrol flap lever, ease it over gently by raising it slightly again:
23) CONNECT the cables again:
24) Put all the other trim parts back on and you're done:
m1lky
Auckland
VY SS
Cheers for the tut. Will def do this.
Do you have to do anything to stop faults being logged etc when unplugging the airbag?
Is there any trick to the rear plastic covers? I can't get one of mine back on.
RIP 05
WA Perth
VZ SSZ sedan
Thanks for the pics, just need to find the time now.
