Think ive fried my wiring 96 VS
Kingolive
Kingaroy
1996 VS EXECUTIVE
Alright so,
I ran my battery flat listening to music with some mates, the only set of jumper leads we had were some cheap crappy ones from the $2 shop,
So we hooked everything up, and attempted to jump my car, nothing happened
We got another set and it worked straight away, fired up instantly,
Now ever since using them shitty leads my headlights, dash lights flicker and the tachometer just goes nuts. This only happens when I turn the lights on. Just a bought a new battery thinking we may have fried the old one, but it's still doing it.
Have we maybe fried the wiring or even the alternator?
Just want to get a second opinion.
stick3
newcastle nsw
vz sedan vs ute gsx1400
i say you had a power surge and damage the computer using jumper leads that have no surge protection
the correct way is to hook both cars up and start leaving both cars still attach for a few minutes than shut both down undo the the leads this suppose to avoid surges to both vehicles that can damage electonics
Kingolive
Kingaroy
1996 VS EXECUTIVE
Thanks for the tip.
So i should be looking at getting another ECU?
stick3
newcastle nsw
does it start and is there a burning smell in the engine bay or cab
Kingolive
Kingaroy
1996 VS EXECUTIVE
Yea starts up fine. And no burning smell
Ive got a volt gauge in the car. without the lights on its sits at 12v sometimes higher, soon as i turn the lights on, it will fluctuate between 8-11v
stick3
newcastle nsw
if its starts nothing wrong with the computer than, do all the functions work which is controlled by the bcm
Kingolive
Kingaroy
1996 VS EXECUTIVE
yea everything works the way it should, high beams, a/c, indicators etc. But funny you mention the bcm, because my indicators will just start flashing randomly and then the left indicator will stay on for AGES.
FXST01
The Grey Man
Perth, WA
VP V6 Exec
For starters this should be in the VS section. I think you may be up for a new alternator.
stick3
newcastle nsw
i had a look in the gregorys and it says the voltage should be 14.0-14.2 v
Kingolive
Kingaroy
1996 VS EXECUTIVE
That's what the volt gauge used to read at before we used them jumper leads, but yea, maybe is the alternator
