vs auto onto vn ecu is this possible
Izzey
55
sunshine coast
vn
if i can run a vs ecu and engine harness without a pcm then that might be the way to go
losh1971
North Tas
VE Series I SS Ute
I sold an early VR trans for $40, that had a kickdown cable
losh1971
North Tas
VE Series I SS Ute
VS run a PCM.
losh1971
North Tas
VE Series I SS Ute
If you want to use a 4L60e you will require the right PCM that matches the car it came out of.
losh1971
North Tas
VE Series I SS Ute
VS runs a PCM, VN runs an ECU.
losh1971
North Tas
VE Series I SS Ute
Not sure if there is a seperate TCM available for a VS but that would be one solution. But then having to run ECU and separate TCM would work out way more exi than finding cable trans, if such a thing exists.
Izzey
55
sunshine coast
vn
sorry I'v got it wrong and mixt up the tcm and pcm . start again
what does the pcm control
losh1971
North Tas
VE Series I SS Ute
PCM controls both.
