Izzey
- Dec 23, 2020
- 34
- 1
- 8
- Age
- 55
- Location
- sunshine coast
- vn
motor and box correct
You will need mafless tune for a start. You will require the matching harness for the trans.
thanks i was thinking of going down the road of ecu (maybe it is a pcm im thinking of ) and harness that matched the box i have (not sure of pin number but a 4l60e ) .will probly then look at a dash to match the system usedSo to summarize,
VN/VP ecu (808) only runs the engine, used T700r4 (4l60) hydraulic style or manual transmission.
VR/VS PCM (424) runs the engine and the transmission. i,e the 4l60e
Points to note.
VN/VP use a reluctor type speed sensor, VR/VS use hall effect sensor. At the end of the day this isn't the end of the world as the speed sensor is in the extension housing and I'm fairly sure these can be swapped over to suit.
There are 2 different transmissions used in the VR models. 12 pin (early VR) and 13pin (later VR onwards), the extra pin/wire in the loom is used for the PCM solenoid for the converter lockup. Again, not the end of the world but it would be easier to get the right wiring loom to match the transmission. VS were all 13 pin.
In an ideal world I would be looking for a VR/VS auto wiring loom and PCM. The alternate that has been suggested is a VN loom and stand alone controller for the 4l60e but it's not a cheap option and then there is the VN loom with the older 4l60 hydraulic style transmission option.
