VS will not do a burn out
Can you do a burnout in your VS?
  • Yes & Im Male
    Votes: 47 82.5%
  • Yes & Im Female
    Votes: 2 3.5%
  • No & Im Male
    Votes: 7 12.3%
  • No & Im Female
    Votes: 1 1.8%
  • Total voters
garfa
37
SE Victoria
VY SS
Shaneus said:
My VS is the opposite I cant stop spinning the wheels. Dont try to spin them but they just do. Think it has somet hing to do with the dodgiest tyre I have ever seen, it is called a highway, has anyone ever herd of this brand?
For easy burnouts, put about 45psi in the tyres, wack the auto trans into 1st and give it a bit.
hang on! and the air in the tyre heats up and the tyre blows up! yeah great idea.
also its can be because the rubber on the tyre is rough. but really that would matter bugger all.
Patrio7
3Y3 K4N 5P33K 1337.
Perth, Como
'96 S1 VS Exec
but we only burnouts on a pad at the local track with 2nd hand tires so they're ok to die
Immortality
Staff member
Sth Auck, NZ
i spin my missus V6 auto whenever i get a little excited and takeoff in a hurry, especially if i'm turning outa street but will do it in a straight line also. its got a single spinner and i've got 235.45/17" with federal (US brand, made in asia)tyres, whats worse is the missus probably does it more than me:yeah:
dunny_duck
dunny_duck
Kerikeri, New Zealand
VS II Berlina 3.8i
96vscommodore said:
have you got IRS?? and i think it does make a diff. logical it would because it will tryand level the car out which inturn makes the rear of the car dip considerably this puts much more weight on the wheels and thus makes it ahrder rto spin.
non irs, super low dobis and munroe shocks, steps out easyer now
MBS206
Except tyres are RATED to 60PSi, and heating the tyre up, the amount it will, will raise it around 3 degrees, putting your total pressure at around 48psi, leaving you still another 12PSi before hitting the "rating" which also has a safety factor built into it.
You sir, are a smack!
S
sly06
Guest
Depends on what transmission you have if it is an auto, you have to balance the accelerator input with the brake otherwise on a manual just drop the clutch and when the wheels are spinning, just touch the brake enough so you do a line locker.
kylo33710
Ballina, NSW
VS Exec 1995
It's IRS, Every one of my friends stock v6s with irs cannot do a burnout unless they full lock and do donuts, but all my friends with live axle can do it, including me, i have a stock vs and i can spin it up and keep it going you just have to keep it under 5500 RPM because of idiot proofing it changes to 2nd at redline
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Is it unnecessary dig week? Threads 6 years old let it die. Top points for actually searching though.
