VT kicks over just wont start!!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by braddz93, Aug 19, 2010.
  1. braddz93
    braddz93 New Member
    Red 1999 V6 VT Commodore
    hey guys, i have been runnin in and out of my house all day goin from forums to my car trying to work out why i just wont start, it kicks over well and there is with out a doubt enough power in the battery to start it, having 14V. I saw a few threads sayin give the starter motor a knock with a hammer, or turn my key right to the point before ignition leaving for abit then trying to start, but nothing seems to be working. so could it be starter motor, spark plugs? please help me
    Thanks guys :)
  2. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Check for codes bridge pins 5&6.
    There could be no spark. Check for spark.
    If there is no spark it can be the DFI module/CAS or even the EFI relay.
    If there is spark the ignition side of things are good.
    It could even be a communication failure between the BCM/PCM.
    They talk to each other upon start up. The PCM enables the fuel system. Or even the PCM could be playing up
  3. VTLS1
    VTLS1 New Member
    IPSWICH
    VT S2 LS1 -VX S2 SS LS1
    knock the starter with a hammer is only if your starter motor is buggered. if your vehicle turns over does it start then stop or turns over but not start at all? if vehicle turns over then starts then stops immediately you might just have a buggered keyhead battery,if you have a spare key try that. if the vehicle turns over but doesnt start go through the last reply & see what happens.:)
  4. braddz93
    braddz93 New Member
    i could sit there and it just keeps kickin over and over, no start. ive tryed both sets of keys and yea, somethin muckin up.
  5. gazza.G.B
    gazza.G.B New Member
    vx
    it could be the keys
  6. braddz93
    braddz93 New Member
    yea maybe, they have been droped a fair bit over the years, and they are the original keys from 11 years ago so wouldnt surprize me. how do i go about gettin a new key and all the rest?
  7. sleepa
    sleepa Shiny...
    5.7 VX2 Berlina Wagon, B6 Audi A4, Holden Combo
  8. 50LTRv8
    50LTRv8 New Member
    VT V8 Calais
    Was about to say, can you hear the fuel pump pressurize?
  9. RichoKidd
    RichoKidd Obese Commodores
    Perth, WA
    VE Sportswagon
    Only way you can get them is to call Holden and give them your arm (or $550.00) Then you gotta get it coded (Another limb)
  10. braddz93
    braddz93 New Member
    umm im not to sure what to listen out for, whats it sound like when the fuel pump kicks in?
    I might just go to holden either way and get new keys, these ones are pretty f*cked lol
  11. sleepa
    sleepa Shiny...
    The fuel pump should make a whirring noise a second or so after you turn it to ON. Turn the radio off so you can here it.
  12. braddz93
    braddz93 New Member
    just went out to try again, i can hear the fuel pump turn on, so i take it thats not the problem. I had a read through the owners manual, and it said to turn key to ON position ad leave for 2 hours turning all accesories off. i did this 2 hours was up tryed and still nothing! after it kicks over and i turn the key back off, i can hear this clicking sort of noise comming from the throttle body area. its really pissing me off lol. so thats were im at
  13. braddz93
    braddz93 New Member
    Hey mate sounds like ya now what ya talkin bout, how do i check for spark? and if there is spark how to i check the BCM and PCM?
  14. braddz93
    braddz93 New Member
    ive also notice, nothin comes on in the screen part of the dash. whats that mean?
  15. bhopper
    bhopper New Member
    east of melbourne
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Hi there so is your led turning off when you try to start it , and i take it your lcd screen isnt switch from klms to instants etc , mmmmm sounds interesting ,just guessing maybe your key barrel is worn, bcm is nackered. Have you bridge the diag connector to see if any codes have been spat out. Also could be a bad ground check you ground wires from battery to body and batter to engine block. Is your starter motor turning motor over just not firing or nothing.
  16. -_-"
    -_-" New Member
    Central Coast, NSW
    VT
    i have pretty much the same problem :( but mine some time started some time keep kicking over and over,..
    just few things i realised, if i let the key in on position till fuel pump stop pressurised, i could not start the car but if i hop in and put the key in and started it staright away, it started (some time)
    So, if i couldn't started, i left the car there for few mins, and i can start mine again..
    can anyone help me too ? what could be the problems ?
    and thanks to Braddz93 to start the topic :)
  17. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    People if the car turns over but does not start you have to go through a process of elimination not guess work.
    First of all check the codes bridge pins 5&6. If there is no code then
    Check for spark. With a spark plug tester (Repco sell them)
    If there is spark then check for injector trigger this supplies the fuel in to the engine. (Use multi-meter) Make sure the fuel pump is working.
    If there is no spark check for EFI relay,CAS,DFI module,Coil pack.
    You need fuel/air/spark to fire a engine
  18. braddz93
    braddz93 New Member
    how do i check them pins? were are the etc, and also how do i check the injector trigger?
    checked for spark today and it has spark, fuel pump starts up aswell.
  19. -_-"
    -_-" New Member
    Central Coast, NSW
    VT
    guys, mine happened again this morning, was kicking over and over and over but didn't started , tried it for like 5-10mins , then sudden started from nowhere .. i getting panic as don't know when the car gonna start or not gonna start ..
    another thing i realised , it alway happen only in the morning. also, after the car started i can switch off and i can start it again every time , never have any problems.
    thinking about getting new key but don't really wanna spend money if it won't fix the problem tho
    what you reckon about the injectors , could be leaking over night and flood the plugs ?
    Thanks for all ya helps
  20. -_-"
    -_-" New Member
    Central Coast, NSW
    VT
    Anyone ???
