VT kicks over just wont start!!
magoo
magoo
shellharbour
VU SS
Have you taken it to a mechanic, i reckon it a old kill switch thats been disconected and not totally removed and intermitting ,thats what happend to my ss and it had the same dramas .it most likely not it but just a thought
B1OHZRD
vic
VP Berlina
It could also be the harmonic balancer sensor, try pouring water over it and then try starting it.
-_-"
Central Coast, NSW
VT
No, not yet. and don't think it's kill switch as i asked previous owner when i bought the car
Thanks anyway :)
no, don't think so cause it only happened in the cold morning
Thanks anyway :)
scottysvtcommie
south west rocks, NSW
05 vz calais
hya mate i just recently had a similar problem, car would crank over easy but wouldn't fire n some times it would, it was mainly in the cold mornings and nights it was worse but it turned out to be my fuel pump relay under the bonnet was stuffed, so it wasn't pumping fuel thru so wasn't firing. try swapping your relay with the horn one and see if it works than, i had holden and lock smiths telling me it was my ignition barrel sensor or my key not reading etc but i checked a few other things and found out it was just a cheep relay not a $400 job to get my key and ignition barrel sensors etc replaced.
cheers scott
Camo_03
33
melbroune
Holden VZ R8 Maloo 297
your injectors could be rooted, cos sounds the same as what i had, and i just wasnt getting any fuel into the engine.
-_-"
Central Coast, NSW
VT
cheers scott
Thanks mate, i'll check that
This is what i thought, how much did it cost you to change a set of injectors?
cheers
braddz93
Red 1999 V6 VT Commodore
still havnt got it going, just noticed that nothing comes up on the lcd screen in the dash it just glows the usual green but nothing comes up, is this a sign of some sort? thanks
FstStig
Diagnostician
34
Central Coast, NSW
2010 VE SV6
You could have a Clogged Fuel Filter.
Your Coils or DFI moduel could be stuffed
TPS or MAF Could be stuffed, try giving your throttle body a clean with some Carby and Throttle Body Cleaner
Check for a Spark on all Cylinders, Take the end off at the Spark plugs, put a long screw driver in there and get someone to see if there are sparks coming out.
ECU could also be buggered, Check all your Fuses and also Vacuum Lines.
Also Check your Air Flow Sensor. This could very well be buggered.
