- Apr 15, 2006
- 22,688
- 20,703
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
You missed my point. You're talking about making clearance for a valve to stop interference. That is different to setting correct PTV clearance.
Not at all. Piston to valve clearance changes depending on the cam specs.
You are talking about changing cam timing to achieve some set clearance as the valve chases the piston down the bore. Changing cam timing to achieve some magical PTV clearance..... If you have a really big cam without fly cutting the piston you would have to retard the cam timing a huge amount to achieve that on the intake but what about the exhaust? Nope, I think I'll degree that cam as per the cam card and just make sure the PTV clearance is acceptable (but then again, on the 304 you need a huge cam before PTV clearance becomes an issue so I'm not bothered).
