304 Why so sluggish?
stocky
here you go guys
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
as for fuel it dont seem to be that good it drinks it realy
eaton v8
my little sleeper
gladstone qld
thats the same one
eaton v8
my little sleeper
gladstone qld
when idleing are the revs going up and down or is it just rough when i had the manifold leak it tended to go up and down like its hunting
ari666
250,000 hits
Profile Actuation Make/Model R/Ratio
1069-12 Flat Tappet Holden V8 304(pfi) In1.65 Ex 1.65
Cam Lift Duration Duration Valve Valve Lift Phase
Adv @050 Clr Lift tdc <)
Intake 296 282 222 Hyd 0.4884 056 112
Exhaust 297 284 222 Hyd 0.4900 041
ok! im gonna have another stab at this;
so, im totally gonna be wrong, but whatever. total valve lift if 488 and 490 which is kewl enough to run stock springs and not cause any trouble.
and duration is 222 which is a real baby, which in my mind, added with efi shouldnt even lope on idle. so it shouldnt be lumpy at all, smooth as a babys bum.
im not gonna bring up cam timing and wether you installed AM timing gear or not cos' i have proved myself to be a twat with that once before. but just to chuck it in there; is your timing chain set to 0 degrees? or is is stock cos stock is usually retarded a bit. (i been told 2.5 degrees, but no word of fact to that)
oh and stick a vacuume guage on it and give us a rading; i.e betwen 7and 8 and it stutters, or it goes from 8 to 12 but slightly goes up then drops down quickly, or just sits nicely on 11 etc etc etc. itll give us the best idea as to the issue.
stocky
nah it seems to idle fine. sits at 1000rpm while idling, but im waiting for my aldl cable so i can adjust the idle screw thing, as i had to tweak that a bit when i was running the cam on a standard tune
timing chain was just set to standard 9 links, something close to this-
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
cant be far away mate maybe in the mailbox in the morning :D mug the postie when you see him coming
eaton v8
my little sleeper
gladstone qld
i dident put mine in but i got them to put a new rollmaster in it and i do have a nice bit of a lump to the ute not over the top but you can tell there is a cam in there but it is the next size up cam but there is stuff all diffrence between them
ari666
250,000 hits
meh, stock timing isnt really that much of an issue. it would prolly get quite a kick from running a rollermaster chainset cos they ditch the stock retard and let you run at 0 which wade would have ground the cam for. but i doubt thats your prob.
id like to get a decent vacuum reading to get a better idea, although someone like greanfoam would be more help :( but if its mechainaical i can prolly give my 2. anyways im off to bed for the night.
see yaz
burnz
dah dut dut da dah
springfield
VFII SS ute M6
is it 9?? i thought it was 12 links.
they should allso be shinny/blue link's to indacate the correct one's.
