Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 64
Like Tree1Likes
Thread: Alloytec Oil
  1. #51
    Bulldog Edd is offline Banned
    VZ SV6
    Feb 2012
    thanks brother!
  2. #52
    sleek_vp is offline sleek_vp
    VS ute
    Mar 2007
    brisbane
    [QUOTE=torana355;2136560]Hence why i said it "can" indicate the oil is not doing its job.[/QUOT
    yeah but my engine atm has done 7k on 5w 40 magnatec (over it- changing brands next week) and the oil is suprisingly still pretty clean and all i put it down to is being well maintained, way i see it with any oil you use, changed regularly your engne will stay spotless
  3. #53
    VS ute
    Mar 2007
    brisbane
    Quote Originally Posted by Bulldog Edd View Post
    An amatuer question here, if I have 143,000kms on my alloytec 190 (2005) what oil should I use as I just bought the car and want to service it myself. The manual says 10w-30, but does that still count considering the kms?
    yes and no depending on its previous service history, how much the engines worn during those km's, what engine noises there are at cold start ups and how much oil it burns during general driving. if all is good go for it. personally my cars done nearly 170k and iv used 5w 40 magnatec since i bought it at 50k coz the oil was free but in the past 30k its had noisy cold starts (from the valve train- cam followers most likely) so this time i deciding between fuchs penrite or gulf western preferably in a 5/10 to 40/50w. choices choices.
  4. #54
    2007 SVZ Wagon
    Aug 2007
    Hill River, SA
    Quote Originally Posted by Cod View Post
    I'd avoid Magnatech, an oil that "sticks" to parts? No thanks, no wonder the oil sensor got fubar. It's also a no-no for turbo's, i'd imagine an oil with some gummy sticky crap put through it.
    Just go a good quality organic 15-40 or something around there, no need to go full synthetic unless you have spare $$ to throw around. Doing an oil change regularly (every 7500kms) is better for the engine that any expensive oil. I changed my oil and filter on my turbo lancer every 5000kms because it was an easy DIY.
    Oh yeah always let your engine warm up and take it easy before bringing it above 3000rpm. 90% of engine wear is done within the first 10 mins of driving. If you really love your car you should let it idle after a cold start for a minute.
    Best advice is that you DON'T start the engine and sit and let it idle to warm up. Start engine and drive staright off making sure that you DON'T over-rev or over-load the engine for the first 5 - 10 km
    In regard to oil, make sure that it is within the Specifications as listed in the Owners Handbook, that you change it in accordance with recommendations (more frequently if driving under harsh conditions e.g. towing, racing, thrashing etc) along with the oil filter. Why some people insist on NOT changing the Oil Filter at the same time as the oil defies logic. Remember, Aloytecs LOVE clean oil.
  5. #55
    Shooter03's Avatar
    Shooter03 is offline Nek Minnit
    Vz wagon
    Feb 2012
    Narre warren
    Quote Originally Posted by Benboy View Post
    Why wouldn't you wanna let the car warm up for a minute before driving? How can that be anything but good for your car?
    I Used To Have a Open Mind But My Brains Kept Falling Out
    Originally Posted by drewVHSS
    If you wish to buy that, i have some sweat from the ball sack of an elderly yak, if you rub it on the rocker covers of your engine, it'll unleash 1-2 killerwasps of powah!.
  6. #56
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by Shooter03 View Post
    Idling is one of the worst things you can do. Driving it normally gets it up to temperature faster.
  7. #57
    WogBoyz's Avatar
    WogBoyz is offline 435rkw/590rwhp
    08 VE SSV M6 Ute
    Feb 2009
    Cairns, Qld
    I start mine and it may idle for 1min or so while i ready myself then i drive off, never had any problems although with the cam it does warm up alot quicker
  8. #58
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by WogBoyz View Post
    Ready yourself? As in, get out your safety checklist and check your makeup?
  9. #59
    VZ SVZ Wagon
    Feb 2012
    Quote Originally Posted by aaronevolution View Post
    What happens if you pull out of your driveway into traffic and sit idling for a couple of mins?
    What is so bad about it?
  10. #60
    WogBoyz's Avatar
    08 VE SSV M6 Ute
    Feb 2009
    Cairns, Qld
    Correct, i though that was normal? haters gonnna hate i suspose
  1. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-08-2014, 10:00 AM
  2. Best OTR for ve alloytec?
    By EnFoRcEr_001 in forum VE Holden Commodore (2006 - 2013)
    Last Post: 13-06-2011, 12:54 PM
  3. alloytec 190 into a vb
    By white vn ss in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-11-2009, 08:10 PM
  4. Alloytec CAI
    By VZ_SV6_NZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2008, 11:54 AM
  5. Oil for my Alloytec??
    By Phreddy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-02-2006, 11:31 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
