Okay. So diging up an old thread, but thought it was better than starting a new one, for a similar problem...
Have been having over heating issues, and getting bad airlock, with no apparent leaks. The car has almost 300k on clock, so I'm just replacing the entire cooling system; new radiator, hoses, thermostat, temp sensor, seals/gaskets, even going so far as to replace the belt and tension pulleys, and I've already done the pump and fans.
Was wanting to also run twin 'pull' fans on the front in an effort to get more airflow through the radiator. Traffic coming home can be horrendous. And was hoping to be able to run a thermos switch, instead of a manual one through the car. Am I able to run this off the standard temp sensor, or will the extra load cause problems with the ecu?
