alternator removal
funaki
cartwright
holden commodore
Need help on how to remove the alternator from vz 2005 got 3nuts out i thought will be easy but i slide off the alternator it hit the side wall.is there an easy way? your help will be much appriciated..
diysv6
SEQ
VF S1 SV6 STORM A6: VZ S1 SV6 A5
I have never removed my alternator, but I think the design is that you remove the three nuts and each remaining stud has a hex drive on the end. You then remove each stud to drop the alternator away.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Yup, studs need to come out to get the alternator off.
Benboy
Hill River, SA
2007 SVZ Wagon
Here you go, some step by step instructions:
  • VZ Alternator removal and replacement.pdf
funaki
cartwright
holden commodore
Thanks very much guys much apreciated.ill try to get the hex drive to undo those 3 studs
Benboy
Hill River, SA
2007 SVZ Wagon
Thats the Ecotec dude, Not even close to the same.
Sorry about that, was in a bit of a rush when I included the pdf. Here's some more relevant information relative to the VZ V6 :
1. Detach battery cable at battery and remove the engine covers.
2. Use a socket bar to release the serpentine engine belt tensioner and remove the serpentine belt.
3. Pull back the H+ terminal cover and remove the nut, washer and positive wire.
4. Remove the three (3) alternator retaining bolts.
5. Support the alternator assembly then remove the three alternator mounting bolts and lift the alternator out.
I have included a couple of pictures (1) indicating location of electrical connections and retaining bolts on Alternator (2) image of the installation of the Serpentine Engine Belt as it can be confusing when trying to re-install without picky etc. Good luck.
[/URL][/IMG]
[/URL][/IMG]
funaki
cartwright
holden commodore
thanks mate for the pictures.i done step 1to 4 the mounting bolts or studs its got a hex head.im not sure what the right size for this end bit any idea?
Benboy
Hill River, SA
2007 SVZ Wagon
Interesting question. I checked mine and a 7mm socket fits perfectly.
funaki
cartwright
holden commodore
G'day Benboy you mean 7mm normal socket? hope this will be my last Questions hahah thanks mate.
