18 inch rims on VE SSV
Jacob Johnson
Warner
VE SSV Ute
Hi, I recently bought an ssv and am wanting to get new wheels. Currently sitting on 20's but want to go 18s. Anyone else running 18's? And what width and offset would fill the guards best? I'm thinking something like 18x10 +40 offset should fit but anyone know for sure? Also, the car is lowered on ssl springs.
Thanks
Brettly-2008
Vasse
SS Commodore - Ford Territory ... both camps
SS-V ran same brakes as SS, which had 18s as standard, so no issue with that side of things, cant comment on offsets etc.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
As far as I know the 18" VE Series I & II factory mag wheels were an 18 x 8" with +48 offset
Never fitted wider wheels than stock size to a VE, so I can't help with what offsets will or will not work on them
Zehq
2016 VF2 SV6 Black
I went from factory 19's to 18's. Had to roll the rear guards, car is stock height.
18x10 rears, +36
18x8 fronts +30
Zehq
2016 VF2 SV6 Black
Stock single pistons.
EDIT: Although the current setup is compatible with bigger brakes.
VS 5.0
@Jacob Johnson you should note that @Zehq 's rims are fitting over Brembos in the front so will easily fit over standard front bakes on an SSV.
glennho
60
PERTH ,Darch WA
2006 VE SS -1977 HX Premier,2012 Hilux 4x4
18x8.5 rims on sssl springs,245/45 tyres
3_putt
S.A
VE SS ute
Got koya SF01s on mine 18x9 +32 & 18x11 +43. 265/40 & 295/35 tyres. I’ve got a thread up in the “my ride” ve section.
Ice2045
New Zealand
2012 VE Commodore SS Z Series
18x10 rears, +36
18x8 fronts +30
Apologies for bringing up such an old thread. But what are those rims called? Thanks in advance.
