Dale1vs
- Jun 16, 2021
- 16
- 5
- 3
- Age
- 39
- Location
- Harden, nsw
- Vs commodore
Hey guys, I just bought a manual 1997 vs commodore. Was told the keyhead went flat so they tried replacing the battery in it. Did not fix the problem so they went and got a chip to go on the obi slot and keyhead and still wouldn't start. I got it home and put in a bcm and keyhead to match and fixed that straight away. I cleared the codes by undoing the fuel pump relay and then battery then tried to start it. It cranks over but won't start, it went to start a couple of times but cut out after a second. Checked codes and it comes up codes: 46, 59, 67, 73 and 82 which is mostly tcc solenoid issue but what I don't get is that the car is manual not auto? I checked the ecu in the kick panel and the ecu is a 3.8 auto ecu? I put in my nephews 3.8 ecu out of his Ute but still does not start. We were thinking it maybe could be CAS causing the issue or DFI module. Maybe blocked fuel filter or dodgy fuel but it was almost empty and I put $10 in it but now stumped on what it could be with the auto codes coming up.? What do you think.
