20 x 10.5" wheels
Troyziee
MY17 SSV-R Sportwagon
Standard height i dont think they will.. mines already been lowered on coilovers an guards rolled. Guy who done my guards reakons should be ok his putting 11s on his wagon
What's clearance like on the inside of the wheel well? Running +36 I only ever worried about the outside guard, but thinking I might change and bring them inboard a bit, but is there plenty of clearance for a 10.5 moving inwards (and running a larger tyre)
Joshyy89
Vf2 ssv
I ordered the SF11 for my VE SS, after humming and harring over offsets, Koya recommended for best fitment to keep it flush with guard with zero fitment issues 20x10 45+ rears and 8.5 30+ which im getting and will clear my Brembos all round..
From abit of research seems like HSV VE VF can run a wider and slightly more aggressive offset due to the guards being more pumped.
The offset doesn't change the concavity of the wheel only where it sits from the hub.
Yeah ive ordered the sf11s aswell. I wenrlt 20 x 9"s +32 im pretty sure. There giving me a +42 offset with the 10.5" told them i was looking at eventuality going to harrop or brembos brakes so there giving me hsv specs.
I told them i didnt wanna run 275s with a streached trye so they said with guards rolled an 295/30 should be sweet but just unsure. Prettt sure guards are the same between ss an hsv from what ive seen
What colour did you go?
Joshyy89
Vf2 ssv
Haven't got them yet mate. I know 10.5 should fit more worried about having a fat tyre aswell
dimetime
ve calais 6lt
Id suggest 265/30 (uncommon size) or 275/30.
I have a 20x10 40p at the moment with 285/30 and every 10mm will count depending on your height!
Joshyy89
Vf2 ssv
hmm i asked koya bout 285/30 they said would be to small to factory 275/35 (HSV) so they either say 275/35 or 295/30... height atm but coilovers
panhead
NSW Central Coast
Cars
Personally I believe the side wall on a 295/30 is too high but that’s just my opinion
I used to run this size with a 255/35 on the front and I always felt it looked wrong.
When I went to a 285/30 the front/rear look was more balanced to my eye.
What size tyre are you intending to run on the front with those 9’s?
dimetime
ve calais 6lt
hmm i asked koya bout 285/30 they said would be to small to factory 275/35 (HSV) so they either say 275/35 or 295/30... height atm but coilovers View attachment 192601
Id think 295 might be to big at that height, id say as long as your in the 275 285 youll have better luck with no scrubbing if you want to keep it at that height, worst case with the 295 is that you adjust your height or stiffness if it scrubs to much.
And just remember the tyre size koya are suggesting is probabley to keep your speedo in, i have 255/35 on my front 20x10 and its often that guys running a 30-35p offset will run that on the rears too!
Joshyy89
Vf2 ssv
I was going to go 255/35 front 285/30 rear cause didnt wanna go 275 untill koya told me to put 295/30
Maybe should jusy run 275/35 an be done with it
Joshyy89
Vf2 ssv
Hmmm maybe but im more worried about keeping rim protected. But also would rather keep speedo close
