rhysyboy44
- Jan 27, 2022
- 3
- 0
- 1
- Age
- 33
- Location
- Queensland
- VZ 5.7 v8
hey guys, i have a 2004 VZ 5.7L V8 it keeps randomly going into safe mode but usually once i pull over it will fix itself after multiple power cycles but now it seems to be getting worse and taking longer to restart. The fault is referring to the electronic throttle control system as per manual so i have replaced the fly by wire throttle body with a new part. Initially the problem went away for about 3 or 4 weeks but has now started happening again and its getting worse i would like to try and replace the accelerator pedal as i believe now maybe its the pedal that is intermittently faulting. I have a part number for the required pedal (92189343) but cannot find anything anywhere as they are a redundant part now, people in this situation what have you done ? is there an aftermarket version made due to demand ?? i just find it hard to believe that the car could be rendered useless all because of a pedal and that nobody has any other options please help
thanks
rhys
thanks
rhys
