mikeryantipp
Hi all. As always when I fix one issue another appears...
When replacing my brake fluid reservoir the other day I checked my coolant level with the coolant dipstick and noticed that the dipstick was dry. I topped up the coolant with about a liter of Red Dexcool and said that I would keep an eye on it.
Since then I've driven about 15kms. I checked again this morning before work and noticed that the dipstick was dry again. I topped up again with about 500ml of Dexcool so that it would register on the stick (about half way).
This is quite a loss in two days over 12kms of driving and seems like more than a small leak. I have never had a car with a coolant dipstick before and have always just kept an eye on the expansion tank to check levels. I'd imagine the dipstick is the best way to check the level?!
Has anyone had this before on their 3.0 SIDI and if so where are the common leak points on this engine? All help as always is greatly appreciated.
- I have no white gunge on the oil cap or dipstick so don't think that coolant is mixing with the oil
- I have also not noticed excessive smoke and there are also no noticeable coolant drips on the ground
- The car has also not overheated and the gauge has always sat at about 40%
- The engine bay looks bone dry
