NB66
- Sep 3, 2023
- 26
- 2
- 3
- Age
- 47
- Location
- Brisbane
- VE LPG. The Silver Beast.
Hi Guys, I've got a factory lpg VE and it has the following symptoms. .....Factory LPG Only. LWR Engine.
PO304 (Cyl 4 misfire) and PO300 (random cyl misfire.) Stability Control turns off and very rough idle. Rev the engine a bit higher and the fault clears but check engine light remains on.
I've been told to check battery and electrical connections earths etc and done that. Also checked the ABS sensors and they seem OK. Also changed plugs and coils. Fault still remains.
One mechanic reckons it could be a burnt valve on Cylinder 4.
Others reckon its a bad earth or some sensor playing up or even the ECU. Any ideas ?
And finally...... YES it is a burnt valve on Cyl 4 !!! Confirmed by a leak-down test.... ;o)
