VE 2013 Factory LPG. Codes 0300 and 0304 and u2100. Engine misfire, stability control off etc...
NB66
47
VE LPG. The Silver Beast.
VE 2013 Factory LPG. Codes 0300 and 0304 and u2100. Engine misfire, stability control off and very rough idle. Rough idle disappears if you rev the engine up a bit.
Hi Guys, The latest from the mechanic in this saga is....
Misfire codes PO300 and PO304 and also code u2100, ABS, can bus fault. If the MAF sensor is disabled the above problems don't appear but the thermal fans come on and with the ignition switch off it takes 5 minutes for the fans to turn off.
What is code u2100 ?
