MONARQ
- Jun 5, 2014
- 27
- 0
- 0
- Location
- Mt Maunganui New Zealand
- VH Holden Commodore Royal
Okay, another question. Did you make sure your harmonic balancer hasn't slipped? The timing mark on the balancer won't line up with the mark on the timing cover properly if it has. That would mean that your ignition timing is not set correctly even with the timing light.
You can make sure that the mark lines up by taking the spark plug out on number one on the compression stroke, and putting a screwdriver in the hole and ensuring that the piston is on TDC. Then you can make a mark with a permanent texta or whiteout on the balancer where the timing cover mark says 0 btdc. THEN use the timing light again using your new mark as the reference point and see if it's any better.
Prior to this though, just try advancing the timing by loosening the bolt at the base of the distributor and twisting it a small amount at a time and see if you can get it to idle at all. I'd say that this is more than likely your problem. Larger cams like more initial advance in my experience
The end of the crankshaft has a 'key' for the harmonic balancer, so there is only one position this can be installed & this can not slip or move, due to the key. I think??
I will be trying your suggestion though, & re-time with timing light.
I set the distributor at about 6deg. (as it always was) & the mechanic increase this to about 12deg. but this didn't really help & still wont idle. When coming up to an intersection or slowing down, I have to use the accelerator & brake to try & stop it from stalling.
